mangosteen
Hi All,
I just bought a 1KW MXUS XF40 DD hub motor for my first ebike build.
I noticed that the seal between the side cover and axle (on the freewheel side) is a bit messed up. It looks like around half the circumference the inner seal lip got folded to the outside of the motor. It's a bit hard to see, but it is visible on the right half of the axle in the attached image.
My question is simply whether this is something worth worrying about. If it's important I could ask about returning it, but I'd rather save everyone the hassle otherwise. The seller has offered to send a replacement seal, so I could also just try swapping it out, either immediately or if it becomes an issue. Any thoughts?
