Bryannagirl
100 µW
Purchased a SAMEBIKE folding e-bike. It looked as if it had never ran. It had been passed down to several people so history is unknown. Had no key. Had to drill out and buy replacement key is in battery and has on off switch to BMS. Fixed brakes and tuned derailer. Batt voltage charged to 54.5 and on off switch works. Wires where mess so unplugged and rerouted and connected to controller. Also meter wires cut at meter purchased replacement and hooked it up. All was looking good meter turned on bike and headlight with buttons - brake lights worked front and rear when brakes pulled. Tried throttle first no pwr to motor. The tried turning crank in all three PAS settings still nothing. Disconnected everything from controller except the Hal sensor the three phase wires and pwr and throttle - trying to eliminate e-brake problems - still nothing - disconnect the the Hal and three phase wires - resistance was low and equal between all phases. Checked - phase to motor hub screws - resistance showed open as expected - tried shorting phases but there is no chugging and no difference at all between shorted and open. Note did get a e-bike tester initial test showed Hal was working but second test showed it wasn’t - returned tester have replacement on the way phase test showed nothing but may not have spun wheel fast enough. I am new to e-bikes. As kid worked in bike shop so know basics of bicycles also have electrical and electronic background. So been trying to fill gaps with some YouTube university. - currently at loss. Waiting for new tester will double check connections and maybe remove rear wheel ( note it is mag not spoked ) and look inside - am I missing anything before I brake open the hub - do all E-bike motors chug when phase shorted any other multimeter tests? Suggestions much appreciated - thanks in advance PS from looking at tires I do not think this bike ever was operational - folded and unfolded and passed from one person to the next none have success - I am stubborn and persistent so will keep trying
