fitek
I took apart a direct drive hub motor and put it back together again. Now when I spin it, it squeals like a tire on painted concrete.
I had to use some elbow grease to get it back together so I wonder if its mis aligned or whether I screwed up a bearing?
I took the cover plates off both sides. There are magnets on the outside of the rim and the large center piece has copper windings. It stuck to the magnets after the cover plates were removed. I wanted to pull this piece out and gave it a few whacks with a hammer (with a piece of wood in between) but it didn't budge so my curiosity diminished, I put it back together. When I put the plates back on they weren't centered right (since the magnets and copper attracted each other, moving the axle off center) and so I had to work on it a bit to get it back on.
Any thoughts?
Any thoughts?
