I'm trying to pull apart a rear hub motor built by HTE to access electronics. This is a planetary geared motor and has just a three-pin connector with no hall sensor connector.
I've gotten inside the hub but it has an internal casing covering most of the electronics. On one side of the casing is the planetary assembly, the other side once removing the screwed on cover shows the stator windings but there is another layer of cover on the axle area. There are screws on both the planetary side and the cassette side inside the case as well as an o-ring on the planetary drive gear on the axle, but I'm not sure which of these might help peel away the last layer; pulling the screws on the axle area by the windings did not seem to release anything, nor did the o-ring obviously release the gear. I see one sensor mounted by the windings close to the axle, and guess this must be a thermistor not a hall sensor, though it looks more like an sp41 case and I think has three wires in, so maybe it is a hall - though I would think it would require three such sensors, and they should be mounted on the outside ring close to the magnets. Inside that internal cover I see color coded wires that look more like what I'd expect of hall sensor wires.
Has anyone pulled apart this vendor's motors or any similar motors? I can upload photos later. I'm curious how the three-pin only setup works, it must have some different internal electronics beyond just having hall sensors feeding signals back out through the usual 5 pin cable.
Thanks,
Charlie
Thanks,
Charlie
