John in CR
100 TW
I got to test ride my latest build yesterday. It uses a HubMonster high efficiency 6phase motor on the swingarm as close to the pivot as I could get it without raising the heavy battery higher. In this placement the motor has an effect on unsprung weight of just 2.7kg. With the big 21" moto wheels, the 28t front 57t rear gearing reduction is like putting HubMonster in a 13" OD wheel, so it will have no issues at all with any trail I have the balls to attempt. The top speed on flat road with the battery at 80V was 87kph, which is incredible with a no-load at that voltage of 91kph. The chain and wheel friction and windage are so small that they didn't affect no-load more than just rounding, since I took the chain off and still got 91. Achieving such a high percentage of no-load speed means it will be super efficient at any cruising speed and even going up very steep climbs.
Despite the consensus that moto chain is noisy, this drive is near silent even with 08B motorcycle chain. These big diameter tires are more quiet than my smaller wider tires on my other bikes and only sometimes can I hear the slightest hint of chain noise while riding. I'll do some drive-by videos from a stationary point at the same speed with my various ebikes to demonstrate.
With this gearing it's really something in terms of acceleration, and I haven't even pegged the throttle quickly or tuned the pair of Nucular 12Fs beyond the factory settings for acceleration other than phase and battery current. Though I made mounting holes for them, I didn't think I'd need to use my pair of 24Fs on this build due to the low gearing, and I was right.
It's disassembled now for some final metal work as well as grind and cut off a kilo or more of unnecessary steel and prep it for paint and make the covers. Here are a few pics in the meantime.
The bare bones frame with wheels mounted
As test ridden with 21s pack of Chevy Volt v2.0 module (52ah)
A close up of the motor mount. Note that the pink arrow points to a 1/3 circle of steel that the round axle sits in so the motor installs only perfect alignment. Those openings in the motor are to install blades like I've used with tremendous success before. That's the exhaust side. I will make a close fitting cover with a filtered intake on the left, and exhaust down and slightly rearward so mud and debris won't enter. This motor will run nice and cool even in the most abusive use.
More pics and video to come in the near future.
