Jeremy Harris said:
I've been experimenting a bit with materials and found that thin foam with thin epoxy glass on one side, is a reasonable substitute for thin plywood.
SNIP
Cut into planks and glassed on one side, this stuff takes a fair curve well and is very light. Once edge bonded together, the thing could be glassed inside and out to make a light yet rigid shell fairly easily.
Using light aircraft type construction, with a light frame covered in heat-shrunk Dacron would be another option.
SNIP
Jeremy
I hope I am being useful here... I know I am pushing my own angle... but I'm trying to keep it as informative as possible.
Howdy Jeremy,
Foam/glass has almost completely overwhelmed plywood as a material for boats.
You can build boats of much the same weight - though in true lightweight construction with Moth class dinghies - when they tried foam/glass they needed pretty sophisticated building methods to get down to the hullweights of wood.
The Moth class has
no minimum weight. On that evidence I think that the foam might end up heavier than plywood built backyard style as you suggest. I am not using "backyard" as a pejorative - the wooden Moths were all backyard too!
With other boats with a higher minimum weight the story is different...
With boats The ply is much less labour, but the glass provides a better panel stiffness which is important for sailing boat performance as the hull distorts less under water pressure.
So the extra weight is used up by making the panels in the foam/glass boat somewhat stiffer than plywood for that reason.
They are more prone to denting and have to be kept on a cradle on land, but on the water - they are stiffer and faster.
Stick and fabric In larger scale structures it becomes quite hard to engineer and loses its apparent simplicity.
The big problem is the torsional resistance (actually it is a huge problem with traditionally built boats too). Problem is that anything made of a grid of sticks can be distorted in shear very easily. It relies on the efficiency of the joints to resist this. If the efficiency of the joins is low the boat (or bicycle) will twist along the longitudinal axis.
If you make a gate for your garden out of horizontal and vertical pieces - you need to add one diagonal to take care of these sheet loads.
There is a boat designer "Platt Montford" that specialises in boats of this type - Geodesic Airolights. At one stage they were promoted on their lightness - they seemed to fade away a little as their most popular design is the based on the same design as my balsa canoe - so the boats were the same in terms of volume and shape.
Geodesic Airolight Wee Lassie - 18lbs
Balsa/Glass Wee Lassie - 12lbs
Recently they have produced a lighter version - but I do wonder how durable it is - whereas the balsa canoe was highly durable - rock solid - if a little prone to puncturing the outside glass - it happened around 5 times over 5 years of use - with my careful use.
Going to the Moth dinghies again ... the plywood boats were lighter than the balsa ones, but the balsa ones could be built with a rounded hullshape.
Now I'm mentioning Montford because he does have a
REALLY good idea in his boats. To take the torsional loads he simply uses a Kevlar (high stiffness fibre - aramid) tow (unidirectional fibres loosely bundled into a flat tape.
He builds the stick part. Then runs strands of the kevlar at
45deg angles to the sticks around the circumference of the boat - gluing them down at each place they cross the sticks and fastening at the edge of the boat. Then the fabric is put over the top.
A neat way of increasing the torsional stiffness with a minimum weight penalty! Cool, eh!
As far as structural efficiency goes - with a stick and fabric construction you are back to the same problem of having two separate structures. One for carrying the loads - the other for reducing the wind resistance.
There is a weight penalty in separating these functions.
MIK
It does give a slightly lumpy appearance as water (or air) pressure is applied, but it is quite stiff.
