cycleops612
OK, so manifestly too messy for consumers.
But it has intriguing mass appeal. batteries are evS weak spot. various chemistries have strengths and weaknesses. Logically, big improvements to the weakness can be made by picking the best chemistry (or combined) for the job.
What is needed (& may exist), is a consumer level, cleverly programmed controller with both batteries attached (2 or more inputs).
It can intelligently and rapidly use either (mosfet switches?) alternately, or combine both batteries in parallel when sufficiently equalised (an optimum state the controller strives toward to maximise reserve power on tap).
small lipo and large lifepo4 pouch paks seem the best contrasting chemistries to combine as a sample hybrid example.
When ever power usage drops below a comfortable output for the lifepo4, then it uses spare amps to top up the burst reserve lipo.
Regen, if u must on an ebike, naturally suits fast charge lipo.
Its not a dissimilar paradigm to an hybrid car or phev - choosing from or combining multiple power sources for the wheels.
Vanilla chinese controllers cost ~$20, so using multiple slave/sub, controllers on each battery to simplify or for robustness isnt a prohibitive option.
am not a tech nerd as u can see, but off the top of my head, maybe the forums for "cycle analyst" are populated with suitable tragics . the "wiki controller" thread here on es may help too.
