1000RR
- Joined
- Jun 5, 2014
- Messages
- 23
Hi everyone,
I can't believe that this happened. I was working on my bike all weekend, tested the system with the unmodified wiring harness and it worked great. Me being a man of tinkering and perfecting, I cut the harness wires to shorten them for a clean look, this was fine for the speed sensor and the battery.
When it came time to cut the main harness, things got a little sketchy. There was a yellow wire in the main harness which I have no idea where it goes to since none of the connectors for the LCD or throttle had a yellow wire. This is when I turned the unit on to check and had an error 30 on my LCD screen.
I moved the bike not realizing the battery was on after I powered off the unit from the LCD, saw sparks come out of the main harness which had stripped wires and smoke came from the battery or possible motor area with a bad smell. Unit will now not turn on.
I guess I tried to open the motor after that but can't even open the damn thing. I am thinking the controller is fried, does it have a fuse?
Please help
Still mistake and expensive since this motor did about 5kms. It's also currently my only form of transport which sux even more.
Please help
