Hi people,
I picked up an ebike on craigslist and am having fun with it, but want to see if I can make it a little better. I'm hoping to go 20+ mph for about 20 miles on a charge.
This is what I've been able to figure out so far.
It has an Aotema front hub motor. I didn't get anywhere googleing the serial number, but it has 3 wires coming out of it. From what I can tell from elsewhere on this forum, that should be a brushless motor without hall sensors and be .. fine? Not really worth upgrading for an entry level ebike.
It has a controller with no external markings with 3 wires connected to the battery and another bunch of wires that I assume would go to hall sensors if they existed. Anyway to figure out what kind of controller I have? It has some screws and I could take it apart.
It has 3 lead acid batteries in series for 36V, 9ah. I don't think I am actually getting 9 ah out of them though. It goes about 2 or 3 miles and then power drops rapidly. This was done at 32 F, so maybe it gets a little more in normal weather.
It seems to me that replacing the battery and leaving everything else alone should get me to my 20 mph / 20 mile range.
Would it be as simple as replacing the SLV with something like this:
https://bmsbattery.com/ebike-battery/165-36v-15ah-li-ion-shrink-tube-ebike-battery-pack-ecitypower-battery.html
Or can I bump the voltage up just a bit (44v) and put two of these in series? There seems to be a lot of love for LiPO.
https://hobbyking.com/en_us/turnigy-high-capacity-battery-12000mah-6s-12c-drone-lipo-pack-xt90.html
If I go with LIPO, I can't seem to figure out if I need a BMS? Or do I just get one of the balancing chargers Hobby Kings sells?
Thanks for your help.
