nutsandvolts said:Batteries can be damaged by cold, but usually that would be VERY cold temperature.
I mean definitely below zero centigrade, I've seen batteries permanently die below -30C.
But a question is not as good without more detail, you don't even mention what type
of battery (lead acid? lithium cobalt? lithium manganese? LiFePO4?) and you didn't
mention how cold it got, also you didn't mention what it is or is not doing. Is it just
zero voltage, will it not take a charge?
nutsandvolts said:There is a big difference between batteries left out in the cold for a very long time and batteries used in the cold,
or left in the cold for a short time. I would think it's possible to damage LiFePO4 if batteries were left out in the
cold for a long time, like over winter unused, or for months at a time. Otherwise, I don't think cold will hurt them.
But what are the symptoms? No voltage at all? Will they not charge?
