Drunkskunk
While my bike is down with some welding issues, I decided its a good time to start modifiing things to work the way I want them to.
I've read Fechter's great article on modding the 35A Xlyte controller, and its got me thinking. The only weak link on my bike. Other than flimsy aluminum battery racks, is the amperage limit on the controller.
What I have right now is the centertapped motor, with the dual 20A contoller. I "think" this controller uses the same case as the 35A, but I can't confirm it without some measurements of a 35A. If I understand how this works, its just a 3 pole switch on the output of the standard 20A controller, then stuffed in a 35A case for space reasons. Anyone know for sure?
What I'd like to do is modify a controller to handle 30+ amps on the low speed setting, 20A on high speed, handle 72V reliably, and fit in the same footprint as the controller I have now. The amp switch its self I think I can do by using a 4 pole switch instead of the 3 pole, but as for how to mod the amp sensor, I don't know yet. Anyone built a variable Amp controller yet?
Also, I long ago got rid of all my spec books from school, So no clue what FETs to use, and wear to get them. Anyone have recomendations and sorces on good fets?
