matt912836
I have this hub motor thats been lying around for the simple fact it is a 10 inch diameter motor which is pretty small and only fits on an electric scooter. I wanted to attempt to put it on a bicycle frame but it being so small is hard to put it on a frame with pedals and not have clearance problems with the floor.
The diameter of the hub from rim to rim is 10 inches. It uses 14 inch bicycle tires which are almost impossible to find in anything other than kids bike tires/tubes, nothing heavy duty like I need for the scooter in the first palce. Theres only two possible things I can do to increase the diameter of the tire:
1. Buy the biggest possible 10 inch moped tire that'll fit on here (and the rim being less than 2 inches wide really limits that to the smallest moped tire)
OR
2. Would it be possible to drill holes around the edge of the rim where the rim grabs on to the tire for spokes? Then attempt to lace it up in a 20" BMX rim
Is number 2 even possible? It would seem to be as simple as drilling the right number of holes, with the right size drill bit for the spokes to be used, in the right alignment, then lacing it properly with the right size spokes. Is it do-able or worth it? Thoughts?
I wanted to throw it on a BMX with one single battery for a fast light ride. The hub motor is definitely a fast turn hub becasue even though its the smallest one I own it has the highest top speed. If I did lace it to a 20" that means the top speed would be even higher. Another option I have would be change the cranks to the ones that were on the scooter (shorter so they allow some pedal clearance), but the BMX bottom bracket does not support square taper cranks, so that would be another problem. If worse comes to worse I'll simply throw a moped tire on it and put it back on the scooter it came from. Only reason I haven't yet is because the original tire that came with it is prone to pinch flats when going over bumps at speed, even with the scooter being full suspension. The 14 inch bicycle tire simply wasnt made to take abuse like I throw at it.
OR
