If you post a pic of the insides, I might be able to point out where you can tweak it.
There seems to be a large number of variations on the designs, but they all have the same basic operating principle.
On the secondary side, there will be a zener diode or IC voltage detector that triggers the emitter side of an optocoupler. Tweak the zener/voltge detector. It may be difficult to get the output precisely where you want it with fixed components.
If you are lucky, there will be an adjusting pot on the board you can just use a screwdriver to adjust.
