HI Everyone.
If like me your enjoying your new CA and you have a 9-fet infineon controller then you'll need to know that the Rshunt value that worked for me was 5.000 mohm. I found the value by using an Icharger as a current source through the phase windings to the system ground negative on the phase wire and posative to the system ground. I ran the icharger in foam cutting constant current mode at 10.0A and adjusted the rshunt value till the amp readings matched
Darrin
Darrin
