raamonkhan
- Joined
- Oct 21, 2022
- Messages
- 2
Hi All ,
How can i change the initial acceleration on this EV tricycle's throttle, from standing still to its first movement is a big jump forward.
The tricycle has a low and normal speed, but the initial acceleration on both speeds are the same . . .is there a way to restrict the initial voltage/current that goes through the 0-5V potentiometer (5k Ohm) ?
Can i add a "capacitor/resistor/other component" to the 5k-Ohm potentiometer in order to decrease the quick acceleration when the throttle is barely twisted.
I want the tricycle to slowly /accelerate/creep a bit first, before ramping up the speed.
It is difficult to manoeuvre the bike slowly when driving in confined spaces.
It jumps forward immediately even when the throttle is very slowly turned. . . barely start to twist it.
The speed stays the same if the the throttle is held in the same place.
We bought it brand new, to move compost and plants around in a garden on the farm,
but it is very difficult to manoeuvre the tricycle slowly through small pathways and past curving flower-beds as the slightest twist of the throttle shoots the tricycle quickly forward,
although you then move at a slow speed if the throttle is barely twisted.
This is what i could find in the manual that came with the TailG Tricycle:
TailG
Model:TL1500DZH-5A
Here is what the throttle and potentiometer looks like below.
I hope this helps.
Thank you in advance !
TailG
Model:TL1500DZH-5A
I hope this helps.
