Long time browser.. finally signed up to throw out a question…!
First time I’m building a HV system. I’m connecting this ANR26650M1B, 20aH pack (no they won’t all be in parallel hehe, I’ll flip every other line soon for a 16S8P pack) to this 300A ESC. Spark protection is obviously a concern, and the instructions for the ESC states that if the included pre-charge resistor isn’t used, damage will occur.
But manually connecting that resistor beforehand every time I switch battery packs doesn’t feel fool-proof enough, so I’m looking for other solutions.
I’ve ordered the AS150 anti-spark connectors, but I'm gonna run some 2-300 amps out of this system so with that I would have to use two in parallel. And also my BMS system has a nice current sensing system with the possibility to control a cutoff relay that I would like to use… and if a relay is in the circuit I guess the spark problem will affect that too.
So… another solution I’m looking at is inrush current limiters. There are these thermistors from Ametherm that take 50A each. According to the manufacturer support engineer they can be put in parallel as long as they are thermally coupled (in order to heat up together and work as a single unit)
http://www.ametherm.com/inrush-current/ms35-inrush-current-limiters
I’ve done some searching around the forum but haven’t found anyone using inrush current limiter thermistors for this. Does anybody have any experience with them? Would putting them in the circuit eliminate sparks everywhere.. so that connectors, relays, kill switches, etc would be unaffected? Sounds like a nice solution, but would it work…
Ah.. and a related question, for charging, are sparks a concern when connecting the charger to the battery pack, or is it just the caps in the ESC that causes sparks?
Thanks!
Olov
Thanks!
Olov
