Hi there
Thanks for taking the time to reply. I have looked at this in more detail to get an idea of, at least, what some of the pins do. Whilst the Votol has the same connector configuration the pinout is not the same. I do know that this controller is programmable so the other link that you sent is probably not correct either as there are no UART connections. In any case the connections still don't match.
Confusingly the VOTOL diagram seems to show the connectors the opposite way round from my setup but what I did work out and that's by going with the pin numbers as shown by Votol is that:
8 way connector
7 - ground, same as Hall ground, suspect it's throttle ground, also same as main battery ground
2 - Throttle
6 - Throttle
For legal reasons the bike doesn't have a throttle but it does have the 3 pin plug for it but these three pins go to this connector.
4 - 48V switched ignition supply
16 way connector
9 - ground, same as Hall ground, also same as main battery ground
6 - changes between 40V and 0V with the kick stand as the bike does not move with the stand down. Maybe electric door lock?
6 way connector
Hall connections and power are as shown.
This is at least something to go on I suppose. I will continue to search. I have reached out to Lingbo twice with no response. Any other ideas?
