Installing a Motor on One Front Wheel of a Cargo Bike with Two Front Wheels???
Polerkongen
Denmark
Hi - does anyone have experience with installing a motor on just one of the front wheels of a cargo bike, where the two wheels are located in the front rather than at the back of the bike? I don't need to go fast, max 12-15 mph. I don’t think it would be optimal - but I already have an older build with 20" wheels and a throttle, so you can also increase the speed gradually. The setup will only be used occasionally when my wife and I go to nearby events. I’ve searched for experiences but haven’t found anything. The picture I found is not the bike I plan to install it on, but just as an example. I hope some of you have experiences that can help me make a more informed decision.
Thanks in advance ;) Michael
You'd need a single sided hub motor for a front wheel install into a tadplole.
What's wrong with putting a motor in the back wheel? Probably cost less and work better.
Single sided hub motors will cost you a pretty penny because they're specialized components that rarely get sold.
Your speed requirements are very low, so i'd pick a rear motor... because two motors would be exponentially more expensive.
You'd want 2 motors if you were climbing really steep hills often.
It was mostly because I had a 20" wheel with a motor, battery, etc. as a spare that I was considering it before buying a 3-wheeler. I already have two others that are rear-wheel driven, so that's also what I'm used to.
Steep hills are the last thing we have here in Denmark ;) I think I'll find another solution, thanks (y)
