chuyskywalker
So, I've got these 4 components:
On the MXUS adapter, there are two exceptions.
I attached a bunch of photos of the motors, cables, and other such items at the end.
Here are the configurations that work:
Any thoughts, ideas here? I'm not sure what troubleshooting steps to take next.
- MXUS XF19FAT Motor (geared, 1200 watt)
- RadMini4 Stock Motor (geared, 750 watt)
- Frankenrunner
- Phaserunner v6
- The motor's white wire is a temp+hall combo signal. The adapter takes motor white -> L10 gray (which, according to the manual, the Runner with demux into pulse and temp readings). When connected to the Frankenrunner, it does just that perfectly -- I get reasonable temp readings and the speedo on the dashboard works when spinning the tire by hand.
- The white wire on the L10 is connected to ground as I found some odd behaviors when connected to the Phaserunner (weird speed reporting; floating voltage?)
Frakenrunner -> RadMini
Phaserunner -> RadMini
(I've been riding the bike in this mode, works flawlessly)Frakenrunner -> MXUS
Phaserunner -> MXUS
is failing in some odd ways.- Most obvious, is that it fails autotune with an "Invalid Hall Pattern" error during autotune.
- It shows a 10.38Kv compared to the Frankenrunner detecting a 9.35Kv (it runs noticeably faster during detection).
- I noticed that speed is always reported as zero, as if the demuxing from the temp signal is not actually working.
