I am a bit disappointed at how difficult it is to remove/ install the front thru axle on this shock system . There are 2 allen bolts on each fork that have to be lossened , then theres another big allen head that is used to screw out the axle and I find that when re-installing the axle it is quite hard to align properly and usually needs a rubber mallet to bang the axle it thru so the threads will engage on the other side of the fork and it can be retightened. This setup up is much more difficult then the thru axle design of the ROCKSHOX.
Has anyone did a modification to the DNM thru axle design to make it quicker/simpler for disassembly/installation or do they sell a aftermarket thru axle that is similar to the rockshox forks and doesn't require allen wrenches/ rubber mallet ?
