Russell
IMO a wattmeter of some sorts is a "must have" for any E-bike enthusiast. I originally bought a Watt's Up meter over a CA-DP for a few reasons;
1) WU was cheaper
2) I could use the WU when I recharged the battery
3) I didn't have a controller with a CA connector
4) I had a geared motor so even if I had a CA connector the speed function would not work
5) You can't quickly remove the CA
I could have bought the standalone CA but that was more money plus it required running wires to the shunt and a wire to the speed pick-up making it less attractive than the direct plug-in version. So I bought the WU meter and velcro'd it atop the handlebar mounted controller like so;
The display was fun to watch and it allowed me to manage my power use and ride with great efficiency. I had installed Anderson connectors on the meter leads, and on every other power connection, so I could remove the meter quickly and use it to monitor the battery charging process. I learned a lot about SLA, LiMn, LiFePO4 and LiPo characteristics by observing the meter during charging. After a while though and especially when I purchased a larger capacity battery I didn't really need the meter while riding. I did still want some kind of visual battery indicator so I opted for an inexpensive LED light/voltage indicator.
The LED voltage indicator was really all I needed to monitor the battery condition plus the big dual LED headlight worked well as a daytime running light. It was cheaply made however and fell apart after about a year's use. Since then I have ridden without a display device and I really don't miss it too much. My power use is pretty consistant and I am so familiar with the motor I can feel when the battery is geting low. I do still use a wattmeter during charging however. I also connect it to the battery in the rear trunk bag to get some hard data when I am trying out a new controller, motor or battery.
So yeah a wattmeter is invaluable and the CA is a nice one. If you have a controller w/ a CA plug, have a DD motor, are running over 60V and have just one E-bike then it's a great choice. Even then I still think it's a good idea to also buy a WU meter.
-R
1) WU was cheaper
-R
