I have a 48v/1000w rear wheel kit I am currently installing. Because of where the controller will be mounted (in a hard saddle bag right near the axle) I can cut at least 20" off the 3 phase wire lengths. From the axle to the controller will only be about 12 inches.
1) Should I shorten the 3 phase wires for reduced resistance and loss?
2) The kit came with a cooling block. Should I use the 3 phase cooling block even if the wires are shortened?
Thanks for your help!
