neptronix said:If you can find a place that can do a motorcycle dyno.. you can probably convince them to do a dyno run for you![]()
tdneVmoDK said:neptronix said:If you can find a place that can do a motorcycle dyno.. you can probably convince them to do a dyno run for you![]()
If i put on a 300 volt battery, 300 volt 1000 amp controller, it would kill a motor that is only capable og 60 volts. So how do i find out what the motor i rated to? There a no markings og signs on the motor. It is a hub motor form an erider.
ZOMGVTEK said:There is no way to know what the factory 'rated' the motor, if you don't know what motor it is.
Most people on here run stuff well beyond its limits. It's not like its indestructible at the rated power, but blows up 20% above it. It all depends on how its used. I'm running 6-8X more power into my hub than it was rated for.
The size and type of motor will give you a good idea of its capabilities. 1000W motors are fairly big, 500W are small, and 250/350W motors are often tiny. Geared 500W hubs generally can't take much more than the ratings, whereas DD 500W hubs can often take 2KW fairly well. Again, go up a very big hill at low speeds, and most any motor will melt. Look around at other motors ratings to give you an idea of what yours might be.
If you have access to a dyno, increasing the power until the efficiency starts to drop off will give you a good idea of the upper limits. If it puts out 1,800W with 2kW in, and only 1,900W with 3kW in, you know to not run it past 2kW. Below that 'reasonable' limit, its just a game of how you want to use it. If you can understand its thermal limits, you can manage it at the upper limits. If you don't want to care about the motors temp, you might want to back it down dramatically. As long as the motor is cool, it should be happy.
Arlo1 said:I found a rule with electrics in general is 8-10 x there rating for a 10-30 sec peak!
Sorry my gf was bugging me for being on my phone while in the grocery store. What I ment was HP ratings of motors.tdneVmoDK said:Arlo1 said:I found a rule with electrics in general is 8-10 x there rating for a 10-30 sec peak!
Don't understand?
Magic?miro13car said:There are PMDC motors which cannot be destroyed by overvolting or over current , they cannot be burnt at all , they are elecrically and by temperature undestruciable.
Yeh I call 100% bull shit! Every motor has its limitsparabellum said:Magic?miro13car said:There are PMDC motors which cannot be destroyed by overvolting or over current , they cannot be burnt at all , they are elecrically and by temperature undestruciable.
Right, like almost every commercially available system is limited slightly under the capability of its weakest component.Alan B said:The motor is not indestructible, but the controller may be programmed to protect it and prevent damage. The system is protected.
Again its not the motor that is saving it self it is the controller being Programed to not hurt the motor the way I have done it since day onemiro13car said:Think before jump and start posting.
Read carefully before responding to a thread.
Repeat,
those motors TF and Eplus cannot be electrically destroyed,
I said ELECTRICALLY , read carefully , not mechanically, you can smash against the wall everything and destroy of course.
why ?
Knowledgable people already know why.
Read a little more on BLDC motors and controllers before jumping in.
Yes, they have limits, those limits are overvoltage, overcurrent, overtemp. protecions,there are easly available electronics to execute such protections, but that cost$$$, not on $300 motor for sure.
So no BS here.
those motors will not allow you to damage them.
Repeat,
why ?
So no BS here.
Again, almost every cheap motor can not be electrically destroyed working under its specifications in its system. That why you can feed 10kW in 500W rated motor or 200V in 36V rated motor. It even can work at this and much more monstrous specs continuously if you can keep the system cool enough.miro13car said:those motors TF and Eplus cannot be electrically destroyed,
Arlo1 said:Sorry my gf was bugging me for being on my phone while in the grocery store. What I ment was HP ratings of motors.tdneVmoDK said:Arlo1 said:I found a rule with electrics in general is 8-10 x there rating for a 10-30 sec peak!
Don't understand?
Typicaly if its rated to say 1hp you can spike it with 8-10x that for 10-30 seconds at a time. But Im not sure if you can get 8-10x the hp out.... or if you are just getting some more out minus increasing losses.... IM working on my motorcycle dyno should have it done in ~ two months so I can gather more data.
miro13car said:from frst post-
" how many watts it can produce..."
Motor cannot "produce" any watts of power,
it draws watts of power from battery when it runs converting electrical energy to mechanical energy.
Consumed power is basically rate at which electrical power is converted into mechanical one.
Also I want to mention...,
very often on forums is presumed that ALL PMDC motors should burn/destroy itself when pushed to the limits.
Not so.
They will not allow you to burn them.
They are high end USA-designed and bult motors like Tidal Force and Eplus motors.
