Adam_0326
Hello everyone, I’m brand new to the group but would consider myself to be quite experienced with electronics. I build custom batteries of all sorts as a side job and one of my customers asked me if I could rebuild a 73.6v Segway battery for him. My issue is that I have thousands of 18650 lithium ion cells on hand but I don’t have any 18650 lifepo4 cells.
Obviously the voltage ratings are both completely different for each battery chemistry so the current lifepo4 bms wouldn’t be compatible when using the lithium ion cells. I was thinking I’d use 72 individual Li-Ion cells to make a total of 18 cells (4P18S) (75.6v) rather than the 92 individual lifepo4 cells that make a total of 23 cells (4P23S) (73.6v). What I’m confused about is the 5 wires that go from the bms directly to the connector. I’m guessing that it’s some sort of communication link from the bms to the actual Segway ? Has anyone ever done this before ? I haven’t gotten started on this project yet because I want to be sure I’m not going to be causing any damage. Any advice or knowledge would be much appreciated. Thank you!
