Hi guys,
I recently upgraded my lights to a M99 Pro (https://supernova-lights.com/en/products/m99-pro) and M99 Taillight 2 Pro (https://supernova-lights.com/en/products/m99-tail-light-2-pro).
My bike is a Frey AM1000EX, using a Bafang Ultra.
I wired the lights directly to the motor (used only + and - cables), which means the lights turns ON automatically with the ebike battery connected, and turns OFF when you disconnect the battery or wait 4-5 minutes (using the motion sensor).
The front light works ok, but I have an issue with the taillight.
I wired it to the front light using the Supernova Y cable (https://supernova-lights.com/en/products/y-kabel-fuer-m99-tail-light-an-m99-pro) and following the manual:
I also have the brakes connected (https://supernova-lights.com/en/products/m99-pro-anschlusskabel-fuer-bremssignal-fernlicht).
Now, here is what should happen with the M99 TL2 Pro according to what I saw online:
- The ring should be always ON
- The central leds should turn ON when using the brakes
And here is what happens:
- The ring is ON when using the brakes
- The central leds are never turning ON
I checked the wiring multiple times and it is not a very complex one, so I am wondering if somebody else did the same and what is the result.
Because knowing if it is a faulty device or if I did something wrong would greatly help me.
Thank you.
Thank you.
