The Speaker Guy
- Joined
- Jan 5, 2012
- Messages
- 73
Hi
Working on next quad sociable, and will use a jackshaft on passenger side to offset chainline for wider rear wheel base.
If the rear is a 7 speed derailleur, is there any limit to diameter to consider for the jackshaft sprockets?
Of course, upper limit is similar to front sprocket, but is there a lower limit? Smaller is better for size, and less torque on 12mm shaft, but I am worried about performance with rear derailleur.
Donor is Rad Mini, with a 48T chainring to an 11-34T 7 speed cluster.
Thanks in advance
John
Thanks in advance
John
