Lock
http://www.jobymotors.com/
8.2-18 kW range of motors...
One model for example:
About Us
Joby Motors is producing lightweight, ultra-efficient motors for use in electric aircraft. These brushless permanent magnet motors attain high torque at low speeds, while retaining a high power density.
The design team is currently building 5-10 kW motors for small aircraft while simultaneously building 20-30 kW motors for future vehicles. In addition, Joby Motors is developing customized, highly reliable and robust motor controllers.
Joby Motors was founded by JoeBen Bevirt, an inveterate entrepreneur born with a passion for engineering that has driven the formation of two successful companies over the past 10 years.
In early 2008, JoeBen turned his focus to renewable energy and founded Joby Energy Inc. to develop groundbreaking airborne wind turbines to harness the power of high-altitude wind.
This engineering challenge required the development of extremely lightweight, highly efficient motors and motor controllers. Optimized for turbines and electric aircraft, these unique direct drive motors have undergone extensive testing and optimization cycles.
Joby Motors is comprised of a growing team of dedicated and talented engineers and technicians representing the finest in motor and motor controller designers from around the world.
Construction inrunner
Nominal Voltage 70 - 100 V
Poles 46
Nominal RPM 2500
Maximum RPM 3500
Diameter 200 mm
Mass 4000 g
Length 75 mm
Continuous Torque 53 N-m
Continuous Shaft Power at Nominal RPM 14 kW
Peak Torque 80 N-m
Peak Shaft Power at Nominal RPM 20.9 kW
Price $1,299 USD
Standard Available Windings
3 turns 29 rpm/V
More standard windings listed here
http://www.jobymotors.com/public/img/products/joby_motors_windings.pdf
