K1 BlackBox 3 - Smart Bafang CAN unlocker with Auto Set Speed Limit, also to set motor parameters M500 M510 M560 M600 M620 M820
Hello
Hi , I have a bafang 620 can bus I think it is it's the new one, it's on a nireeka mega it's ok , but id like to up the amperage from 20a -40a can I get a program to set up the increased wattage and amperage going through it it's 48v ATM it's going to have 20ah plus the bikes 17.5ah in series so 36.5 ah and 1752 amh is there a way to program the can bus bafang 620 yet? Thanks in advance
It is not possible to set max current. It depends just about the firmware. Usually M620 is 30A. We have one 52V 40A firmware.
Brand New BBR Ultimate with option to remove throttle speed limitation.
M510 FC2.0 is limiting at 32kmh
M560 is limiting at 45kmh
Device is cabled between motor and speed sensor.
Show real speed and also Trip and ODO meters compensation implemented.
Will work also on M420, but there are different connectors. :( So I have to figure this out first. To order some motor...
Did you ever manage to figure out how to get it to work on the m420 and what connectors are required?
Or is there a better option for that motor?
