HAL9000v2.0 said:
skew is 1 pole pitch but ill say 1 slot pitch because windings goes through every forth slot, one circle of wires have two slots between. Number of poles is number of slots divided by 3, is that right ? 72 slots, 24 poles?
Thanks.
I think that you are right that it should be called 1 slot pitch skewing.
Tooth = coil pole
Pole = magnet pole
"windings goes through every forth slot, one circle of wires have two slots between."
=> coil wound around 3 teeth
"Number of poles is number of slots divided by 3, is that right ? "
It is right for your motor. (But not right for PUMA/BMC motors)
For X504
72 slots (or 72 teeth), 24 poles.
1 pole = 180 deg
1 tooth = 180 deg / 3 = 60 deg
Skew 1 slot pitch
A coil of 4 turns spans around 3 teeth.
24 coils per winding phase
The waveform of the BEMF in 1 phase winding looks like a trapezoid with a point-top as shown in the pic.
A 6-step drive would be deemed to be more suitable for trapezoidal BEMF motor.
Note: PUMA/BMC motors have BEMF closer to a sinewave than that of X5.
