Kodin
Been thinking about 15 and 20mm through-axle hubs lately and it got me wondering - What stops someone from making a solid 15mm shaft, popping a hubmotor shaft off a hub, installing a key into the keyway of the stator permanently, and cutting a keyway slot in the shaft so it can slide in and out of the motor effectively without causing issues with the bearings? In order to center the stator, add tight-tolerance tubes that can be snap-ringed either side of your bearings, and butt up to the stator bore. If the keyed shaft is ~0.005mm undersize for the bores, (or thereabouts,) it might be possible to retain serviceability while having a heavy through-axle design available. As far as dropouts go, make them clamping with keyways as well, and just pop in keys when you install the shaft. If anyone likes the idea, I'll draw up some diagrams later to explain the idea.
