kiwiev said:
These used 18650 modules are comprised of 2600mAh cells arranged in a 22p15s configuration. They are rated at 100 amps, 150 amps peak. They have an integrated liquid cooling/heating system, but they can also be air cooled in light duty cycle applications. They also have an integrated 100 amp fuse, and an ATX20 connector with cell level connectivity for BMS systems and two integrated thermistors. The packs contain 330 cells, and each cell is independently safety fused on both terminals.
These features cut out much of the work and make the batteries harder to damage. You can't go wrong with that aspect of this.
They have been lightly used, most with less than 5000 miles on them, and are designed for 100,000 miles to 85% capacity.
If I were ordering them, I'd want some data with regard to their current condition. They may still be slightly above nameplate ratings, which would make them a good solid buy, or they could be showing signs of age young in their life... in which case be careful with your purchase.
How big of a pack and under what discharge and typical trip length can this mileage be delivered? Spending $10,000 on a pack that lasts 100,000 miles breaks even at the equivalent of a 30 mpg ICE car running on $3/gallon gasoline. In Australia, gasoline is probably significantly more expensive than it is here though so the economics may still work out in your favor.
Making the truck have a longer range heavily decreases the wear and tear on the cells thanks to shallower cycling for any typical daily usage case. I see potential for certain lithium ion chemistries to last 250,000+ miles, and LiFePO4 even longer still, but you need to use a battery where shelf-life is less of a factor in their demise and size the pack to where virtually no trips drain the battery fully, and 90%+ of trips take it down less than 25% depth of discharge.
I do not know if the battery you are planning to use can be bought new, left unused for 5 years, and still deliver like-new performance as CALBs without a BMS can, even if they may still end up being very adequate for your usage case.
A preferred configuration for a typical AC50 application is 4p2s for a total of 24kWh of energy with a total of 8 modules. These work particularly well in 48 volt marine and cart applications as well. Quantities are extremely limited, pricing specials are temporary.Capacity: 57Ah, 3kWhHeight: 7.25 InchesWidth: 2.875 InchesLength: 39.0 InchesWeight: 42 PoundsBolt Size: M6 Voltage nominal: 3.8V/Cell, 57.0V/ModuleCharge voltage cut-off: 4.2V/Cell, 63.0V/ModuleDischarging cut-off: 3.3V/Cell, 50V/ModuleMaximum Discharging Current (10 sec.):150 AmpsWarranty Period: One year
Awesome post Toecutter
Thank you
I have these in mind to thinking of 14 modules would like your thoughts please
The specific capacity is nice. 23 kWh to 80% DoD in 346 lbs of battery with a 126V/228AH setup would be wonderful. Given the sheer number of cells(15*2*22*4 = 2640 cells!), I'd personally set 100A from each module as a safe limit. This would give you acceleration performance similar to "Setup 1" in my earlier post above. 150A peak, if they can truly and reliably do this, will make this truck very fast.
How much would they cost?
Maxing out twin 96V/650A inverters with the lightest possible battery configuration that can deliver that level of power without damaging itself is how to size it, if you're going to be wanting the best acceleration performance possible with these drive systems.
With 14 modules, you could do 2s7p for 126V/400AH, assuming they all worked. Imagine a 200+ km range...
Don't forget the truck nutz:
http://www.trucknutz.com/
...because at 150A per module string, you're looking at them sagging to perhaps 110V while getting 1,050A draw from them. You're going to have 250 lb-ft up to 2,500 rpm, peak there at about 115 horsepower, and keep that 115 horsepower all the way past 5,000 rpm.
You probably wouldn't need a transmission anymore, as that's just sucking power away from your wheels.
What are your wheel/tire size, gear ratios and rear-end ratios, by chance? Expected drag coefficient and weight? I could input them into the following simulator and see what performance it says you will get:
http://www.nightrider.com/biketech/accel_sim.htm
And using this graph to determine your motor curve:
http://www.hpevs.com/Site/power_gra...ac50 96 650 amp volts imperial peak graph.pdf
