galderdi said:I would be putting a Fan and fake pulley system on that all the way up to the white box on top. Then I would mount a scoop on the white box. People will look at it and think its a blown V8
Emoto said:Great work there kiwi looks like your being pulled in all directions between projects , love the look of the ute e-v6, makes me want a e-van imagine that, with a false floor in the back plenty of room for batts .kiwiev said:Big day today
I'm pretty pleased how it turned out and looks a bit like a V6. Cheers Kiwi
One thing youve come a long way from doing your first ebike thats for sure mate congrats.
The Toecutter said:galderdi said:I would be putting a Fan and fake pulley system on that all the way up to the white box on top. Then I would mount a scoop on the white box. People will look at it and think its a blown V8
To bastardize a Mad Max quote, he could call it a "Joule-injected suicide machine."
liveforphysics said:Just generally speaking from over a decade of ICE racing, if it's a gearbox it breaks from something you can find a way to do to it.
Something like single belt stage from motor to pulley on OD of a differental housing using 13" kustov on a Zilla 2KHV controller off a used volt pack or >2015 LEAF cell pack would make a bug inspiring to drive.
kiwiev said:So here is a question for the engineers
I have been dreaming about future plans for the blue VW superbug and have 2 ideas
1, HPEV AC 51 specs 88 hp 108 ftlb torque with a 11 Kwh pack weight 90 kg so conversion weight would be approx 150 kg
Would run alloy flywheel and 2 speed box with switch reverse, then strip out weight ie race seats alloy wheels polycarbonate side windows etc.
This option would be budget and hopefully proove you can build a low cost fast EV. Also option to throw in another 11 Kwh pack in the front down the track.
2, HPEV twin AC 51s double above power torque, will need extra 11 Kwh pack to run 2 motors, I know this will be quick but expensive.
So my questions for everyone are
Would it be quicker with one motor and lighter or with two motors heaver by 150 kg and more power.?
Cheers Kiwi
kiwiev said:The Ute is runningdid a wee bit of testing doing 0-100 kph in the 6-7 seconds which im happy with it will pull away in 4th gear but you can drive it like a stick shift
The Toecutter said:kiwiev said:The Ute is runningdid a wee bit of testing doing 0-100 kph in the 6-7 seconds which im happy with it will pull away in 4th gear but you can drive it like a stick shift
Ultimately, what battery setup did you go with and how much does it weigh?
It would haul ass in the bug...
Cowardlyduck said:EPIC!
I'll have to come down for another ride some time soon then. The Fighter is going well with it's new controller and LiPo in place now.
Cheers
