Kiwi
First production batch. Got some in black and some in white, look good mixed and matched.
![wpid-IMAG1761.jpg](/sphere/proxy.php?image=http%3A%2F%2Fevlab.co.nz%2Fwp-content%2Fuploads%2F2013%2F07%2Fwpid-IMAG1761.jpg&hash=4d07685a885ac7e41c58d6d30bba0fe5)
![wpid-IMAG1748.jpg](/sphere/proxy.php?image=http%3A%2F%2Fevlab.co.nz%2Fwp-content%2Fuploads%2F2013%2F07%2Fwpid-IMAG1748.jpg&hash=3242cdda0c5e8557e9b4193b445570e5)
![wpid-IMAG1755.jpg](/sphere/proxy.php?image=http%3A%2F%2Fevlab.co.nz%2Fwp-content%2Fuploads%2F2013%2F07%2Fwpid-IMAG1755.jpg&hash=7f39e6ea214ea6262b61b489bf385dba)
![wpid-IMAG1757.jpg](/sphere/proxy.php?image=http%3A%2F%2Fevlab.co.nz%2Fwp-content%2Fuploads%2F2013%2F07%2Fwpid-IMAG1757.jpg&hash=9eafcc1874b460de0735fe1fcb7ee5e8)
![wpid-IMAG1753.jpg](/sphere/proxy.php?image=http%3A%2F%2Fevlab.co.nz%2Fwp-content%2Fuploads%2F2013%2F07%2Fwpid-IMAG1753.jpg&hash=91d974a34d47e760d5be9efa3020dddb)
Rodney64 said:I'm going to use one of kiwis boxes with the EIG cells that Chris is selling.
15 cells should fit well into kiwis box.
Looking to use it for commuting to work. 20 amp hour pack, 66 volts hot off charge and only 6 kilos. May need to get a new seat first before posting pics.
Kiwi said:Awesome.
I have run into the chain issue on a couple of bikes, will change the corners in a future run.
Also, I will do a run of longer ones to fit 36v20ah, or48v15 pings, 300mm long inside.
jonescg said:Kiwi said:Awesome.
Rodney will love you for itBut then, Kiwis work that way
The EIG packs will end up being about 250 mm long, 140 mm high and 108 mm wide, before any added packaging (add 6 mm to each dimension). They shouldn't need to be any wider, but if you could extend the lid section where it rests on the seat post you would clear the chain on most bikes I think.
