hi I've got a 20 inch fat bike 1000w 48v20ah with kt-lcd3 Meter after change the trottle the bike not going faster than 15mph
some one can give me the good setting for adjust max speed thank you for the help.
it's probably linked in one of these, too:
https://endless-sphere.com/forums/search.php?keywords=lcd3+manual&terms=all&author=&sc=1&sf=firstpost&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
If you have any problems sourcing the manual for the KT LCD3 manual, send me a PM with your email, and I'll send you the full KT programming manual as a PDF file.
Good Luck!
I have read there are two different throttle volt types one 5v one 4.5v if you use the wrong throttle assemble on your bike it may never see full throttle.
I changed the twist throttle because the ebike fell to the ground
and put the original tumb throttle and since the maximum speed is
15mph. I try to adjust the lcd but the manual I have is for the general configuration
KT-LCD3+user+manual.pdf before the top speed was 30mph that's it
it's the same pdf that I have one of the company but it's not my setting to my ebike
example P1 2345 and C1234567891011121314 most of the setting I have now is not original
I used the seller of my mxus motor to find out technical settings as some settings are directly related to the motors magnet count. The manufactures website may have contact info if you dont have the sellers name etc. It could also be your controller has its access crippled by the manufacturer
I managed to solve my speed problem but that take some time while riding to see the speed of speedometer on screen
could someone give me the right setting
thanks for the help
My speedo kicks in at about 15 or 18 kmh it seems or thats how fast im going when i first notice it. When Im off throttle the speedo goes to O this is not a problem its a design problem of the controllers speed interface with the wheels internal rpm speed sensor.
People buy a secondary speed sensor to hook to the controller and disconnect the wheel speed sensor.
I expected the manufacturer of your bike knows about the settings as sometimes they will lock the speed sounds like yours was not locked . My tip is to make sure the wheel size is correct then the speedo should be accurate.
I have read you can fool some speed limiters by inputting a smaller wheel size in that option especially so with the pas only ebikes
