I am finishing wiring my 3 speed switch . After reading how to wire. It's not very clear. Here is what I understand black is the center of the switch and assume black is ground on the controller. blue goes to the other post to slow the motor for one speed. The other post has the red wire but they said it don't work. They said to get the next speed you short the 2 white wires and the black blue wires to get the lowest speed. To get isolation I would have to connect a pilot relay or a multi pole switch. After looking at the schematic the white wire is just connected to ground to enable its speed reduction but the drawing don't have the speed switch in it but I assume the blue is grounded to enable its speed reduction. My idea is to tie white and blue and go to the other post. Has anyone wired this switch this way? Is their any interaction between the white and blue wire connected together?
Thanks
Steve
Thanks
Steve
