Kunteng KT72 with MXUS 3k Setup / Wiring help
DOA
10 µW
Underworld
Looking for help figuring out why my controller is not applying power to the motor. The batteries are dual 52v. The LCD8S display is flashing the battery meter, which the manual says is under-voltage, but gives a reading of 55v. Attached are photos of the wiring, display config parameters, and display.
in regards to the wiring, please let me know if I have this correct and haven't determined what is #1.
1: ??
2: Battery +/-, Phase wires
3: Hall sensors
Motor is 5T
Did further research.
#1 is second set of hall wires.
And it looks like the low voltage cutoff for this controller is 60v.
Is there anyway to modify it? I have the display parameter set to -2v already :(
Resolution? I have an original Juiced Scorpion I’m modding with a 3500 watt mag wheel hub motor. I ordered direct from the manufacturer and is taking “forever” to get here! Like a little kid waiting to open gifts😜🙃🤪 🤞Best of 🍀 luck with your project.
2nd set of halls on the motor - mxus did do a version with 2 sets of halls, they also did a version with curved magnets, next might be a version with rgb ;)
#1 is that a white wire hiding behind there?
