BVH said:Here's a mock up of how I balance charge the 2P pack. Not shown, but obvious are the balance board input cables and balance cable which are connected to my FMA Dual PowerLab 8 .
It may look a little "Mickey" with the alligator clips but they are rated for 10 Amps and I charge at about 4-5 Amps. I did make and use an Anderson 120 Amp-to-Anderson standard connector adapter, just didn't get it out for the pic. It's a little more refined! Any multi-pak balance board will work fine. Since the packs are permanently Parallelled, they are always at the identical Voltage and they are balance charged to within about 3-5 Millivolts. I keep them at 3.75 Volts Per Cell storage charge when not using them. I charge the pack just before use and discharge (if necessary) right after use.
SubnetMask said:After Franks last comment regarding joining the batteries at ring terminals rather than the XT150s, this is what I came up with:kWeld.jpg
The calibration numbers I got out of it were:
1 Pack
R=2.37mR
Std=19.6
I=1206A
T=26.6C
2 Packs
R= 2.19mR
Std= 25.2
I= 1902A
T= 27.0C
I guess that I need to explain something here The displayed resistance from the SHORT calibration step is not the measured internal resistance of the battery, but the resistance of the output leads. That doesn't change with current of course, and the fact that you get a different reading at higher current is due to limited accuracy of the kWeld's measurement system itself. If it would work 100% accurately, then you'd get the same reading regardless of the current. It doesn't need to be a high precision instrument however, because the actual task is to create repeatable welding results, and it does a decent job there 8)garolittle said:SubnetMask said:The calibration numbers I got out of it were:
1 Pack
R=2.37mR
2 Packs
R= 2.19mR
Very nice. Low resistance numbers.
Thanks 8) 8)SubnetMask said:I think to say that the kWeld is better and more consistent than the Suckko welder I had originally tried is the understatement of the century. VERY happy with the kWeld.
Perfect!garolittle said:1 Pack
R=2.20 mr
Std=29.2
I=1530A
T=32.1C
How do these numbers look? Am I ready to go? Thanks for all the great advice.
tatus1969 said:Perfect!garolittle said:1 Pack
R=2.20 mr
Std=29.2
I=1530A
T=32.1C
That sounds like an amazing option for kWeld, since that battery delivers more than enough current while still being considerably smaller than a regular 65AH/100AH starter battery (at least what I can tell from your picture). Please tell me the amount of current that you get during welding, I'd like to add it to the list of recommendations on my website.raming said:ODYSSEY Extreme PC925 12V Auto Battery
-I 1389A
bentms said:Hi Guys
I managed to screw up my original battery supply Wires (I.e the wires that connect the battery to the kweld, not the actual battery wires) so need to make some new ones.
Could you tell me how long they should be? Or is it the shorter the better?
Cheers
Ben
serious_sam said:Sounds about right. You could try with partially discharged packs. That might lower the available current enough to get below the limit.
I'd say your theory is spot on, the copper strips have significantly less resistance and push the current above the limit. I'd also try using partially discharge batteries first.garolittle said:I think I know the answer but I wanted to ask in case I’m wrong. Tonight I was spot welding .25 mm nickel plated copper strips (about 65 - 75 joules). I was curious why I encountered an “over current” message when I used two Lipo batteries in parallel instead of using just one Lipo battery. I have successfully spot welded pure nickel strips (i.e. no copper) many times using one Lipo battery and also using two Lipos connected in parallel but I have never encountered an over current message. My theory is that the nickel plated copper has much less resistance and therefore using two Lipos in parallel triggers the error code. What do you guys think?
