Kingfish said:
^^Oooh! I can see this turning into a build thread
John in CR: Methinks if you put some pedals on with a single rear sprocket that it would qualify. But do we need to pedal as we try to set the record - above 80 mph
KF
Zappy's wooden velo has the potential for well over 100mph. I'm seeing somewhere in the 120-130mph range is possible running as a hubmotor. Use the calculator at
http://www.kreuzotter.de/english/espeed.htm with the Quest velo as the bike, and power requirements get to 10kw at the wheel. I'm getting that already on just 20s, and based on the lack of heat it's nowhere near saturation with 15kw input. No load of 74mph with 65mph top speed with 0 aero treatment also supports that view. The far better than typical stator lams and low pole count of 12 (24 mags), means going to 32s is a non-issue.
Going to 32s puts no-load at roughly 118mph, but that's with a 19.2" OD tire. A 24" OD wheel (a 17" moto tire) puts no-load speed at 147mph, which is just about perfect for 125mph. That's with the Quest's aerodynamics, and I suspect Zappy's is far more aerodynamic. Look at the White Hawk, also in the calculator, and it has only half the power requirements for the same high speeds.
Aero is obviously everything. This analysis is with a stock sealed motor running well below stressful range, so all we'd have to do is tape up the wiring harness at the exit and make sure the axle seals have grease to make sure salt doesn't get in. The tire itself should ensure the motor gets enough air flow for a 5 minute run, but for insurance and an efficiency boost we make some semi-circles of freezer packs and insulating foam to keep the motor packed until it's time to run....or even cooler (pardon the pun) we pick up some of those high power peltier coolers to stick on and run off of solar panels till it's time to run. The motor won't need that stuff, but at least it will give the team something to do while waiting.
Without a wind tunnel for testing we don't know our drag coefficient, so to make sure we don't gear too steeply or leave a lot of speed on the table, it would be a good idea to make up a few different size wheels to easily swap out via the bolt on rim flange. Then do runs with progressively large wheels. That means setting up the frame and wiring to easily pull the rim and tire is a build consideration.
Another consideration is to put 2 freewheels between the pedals and the wheel. At record type speeds a freewheel failure could be horrific with only one between you and the wheel.
A velo is going to need a verital tail to ensure such a lightweight vehicle stays straight. What about some surfaces for downward force?
Who's got the balls to ride in a 150lb or so land rocket it at over 100mph?
John
