What is your question?
Likely designed for cheap FLA, but good ones will have at least a FLA | GEL | AGM switch to change both Absorb and Float voltages
Better ones might have a dozen profiles to choose from.
The best are fully user-custom adjustable, sometimes even allowing current to be de-rated.
Only way to know if you don't have easy access to the maker's tech staff, nor good documentation, is to actually measure with a DMM, and compare with the mfg specs published for your batteries.
