ABritInNY
- Joined
- Jul 12, 2015
- Messages
- 118
neptronix said:That's motor power, not controller power.
I'm talking about controller power ( which is what you see on a cycle analyst )
I too have the 4T motor that you have, which I finally got working to full power for the first time today, (thanks 4 the suggestions Tek,) I also have a supposedly calibrated CA, but mine is the reverse setup to your graph, with 80v batt * 64a controller setup, but wouldn't the wattage be the same? @around 5kw.
Now I'm trying to make sense of this graph data to best setup this motor. I'm trying to work out it's fastest sustainable constant speed in a 26" rim, and compare it to my tests today. The roads aren't flat around me, so it's different to any simulation, but I think mine pulls like 2400w? at 40mph on flat ground and I'm quite light, only 125lbs, OR perhaps the tears were too heavily flowing lol and I saw incorrectly.
When I disconnected the CA and used Runtastic with GPS it said I went 54mph but took near 6kw of power to do it, and I hit 104C in less than 10 mins riding
Wow, seems as soon as you digest one hard topic, the next confusing situation rears it's head!
Do you possibly have a 'safe' top power/speed suggestion for the 4T? One that lines up with both your experience AND what the simulator says (or sumthin in between poss.)
