More updates!
Apparently Leafbike now has the ability to use
cassette freehubs in some of their motors. They've confirmed they can do it with the 1000W unit, the 1500W model was just updated last week and they are still confirming whether this will be possible on that version as well.
Per Leafbike:
* If you need this motor,only place an order for our standard motor,note: “ spline cassette gear ”
Eventually they will upload these options to the site.
Regarding my motor, I'd be fine with the larger cover if that's what it is; I'm building my own swing-arm for a Genesis V2100 anyway. Throwing a DID 1.6"x21" motorcycle rim on it and a Pirelli MT66 80/90-21 tire on the whole shebang.
HOWEVER, this is what I got from Leafbike:
1x set of 48V 1500W rear hub motor (with temp sensor,5T winding rotor,3mm high temp phase wire) – It can be installed disk brake and 7 speed sprocket that still fit for standard 135mm fork.
According to them, they made me a custom shaft for my motor. Also, I just got a text message from DHL that it's out for delivery. Watch this thread for a picture update later today!
UPDATE!!!
Motor has arrived. Left side cover is larger, shaft is wider, shaft is thicker up to just under 135mm. Took lots of pictures and relevant dimensions via caliper.
Photo spam ahead. If you want descriptions of each shot, head to the gallery:
http://zoom-pan-tilt.smugmug.com/Projects/LeafBike-1500W-Motor-Custom/n-9qr7V3
PICS:
3mm phases, halls packaged together with them in a decently thick sheath. Temp sensor goes to the middle pin normally missing from hall plugs.
Cable is long; maybe more-so than necessary, however for certain configurations of frame looks like you'll have lots of flexibility. You can see the extended side cover for the new shaft design.
Spare wire, un-protected other than the small sheath for the temp. sensor. All the tape will be coming off, probably will cover everything with some of that high-temp silicone-and-fiberglass heat shield tubing once I have everything mounted up to the bike.
Cable comes through the bearing, (deeply recessed in the cover), via a nicely-milled circular cut-out in the thick part of the shaft. This ends just at the beginning of the necked-down-and-flattened-on-two-sides threaded section.
Different lighting of the same shot. There is plenty of space in the outer bore before the cable exits to allow for a shaft seal if doing oil-cooling. Definitely will be taking advantage of this.
Difference between covers.
Almost 17mm shaft for the thick section! Damn!
Standard sized flats. Mine is technically 10.03, assuming my calipers are to be trusted...
Eyeballed ~135mm on the caliper, looks like the necked-down part of the shaft is slightly shorter than 135, before the washers are added. Looks good!
Different lighting so you can read the caliper.
Freewheel cover between rotor and widest non-participating-in-freewheel-mount section.
New brake rotor cover is an extra 8mm wider. I assume this is to accommodate the larger bearing and give space so it's mounted inside well.
Rotor clearance: 18.35mm measured from the base of the rotor mount. (Used the right part of the caliper to measure, repositioned here so you can see the measurement).
Distance from base of freewheel thread to necked-down section of shaft.
