ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
calab said:Leaf cast wheel is only on the smaller motor 1000w with one size and it does not fit the bigger 1500 motor how small a wheel do you want I am lacing a iso 305 16" bicycle rim to a hub that will have 30mm spokes and retains 90 degree spoke angle on a zero cross pattern having a wider rim for wide tire would be neat 14" 50cc tires.
That is too bad about the lack of cast wheel for leaf 1500.
In the simulator the 5t leaf 1500 does extremely well at very small wheel sizes. I was even able to beat the GMAC 8T motor using a 28" wheel for efficiency and power throughout the speed range when I used a 14" wheel with leaf 1500 at double the volts and half the amps and half the phase amps.
P.S. Kv for GMAC 8T and leaf 1500 5T are 10.38 and 10.49 respectively. When I make the Kv both 10.38 the results are still basically the same....the leaf 1500 has a substantial lead in power and efficiency throughout the speed range.
