Hard to say exactly what caused the RH212 to fail like that, but yeah it's pretty bizarre and not something I've ever encountered before either.
There were not any obvious external factors and the point it failed wasn't a particularly hard bump, having hit far larger one's prior without issue. I was only pushing 60A peak, but mostly below 25A and only on 14S ~52V.
The spokes were a bit tight as Grin didn't do the best job lacing it, so I had to true it myself, but it was no tighter than other hub motors I have run for many years without issue. I have torque arms both sides as well so it's not like there were uneven forces.
I can only really think it was a manufacturing or QC issue as the structure of the motor is meant to have a magnitude of strength beyond what is needed so for it to fail like this when not under extreme circumstances tells me there was something not quite right somewhere in the metal casting of this motor.
The crazy part is it was pitch black when this happened and I thought it was just a broken spoke so I rode it home for several kms like that and it worked well enough to get me home still pumping over 1Kw through it. :lol:
Cheers
