by The Toecutter » Jun 04 2022 11:01pm
Ellou wrote: ↑Jun 04 2022 10:28pm
How do I know the turns of the motor? I don't see that listed.
If you do not request a specific turn count, Leafbike will send you the default 5T wind motor.
Will a 3t be a nice mixture of torque and speed? On 52v and/or 72v?
3t is the fastest rpm wind available. It makes the lowest torque per amp of any of the winds available, in exchange for offering the most rpm per volt. 6T would be a more balanced wind IMO, but even at 72V it won't provide the 50 mph speed you are after, albeit it will still do somewhere slightly below 40 mph top speed @ 72V in a 20" drive wheel. In contrast, at 52V, the 3T wind would get you somewhere around 45 mph top speed, but you won't get there nearly as quickly given the current limit imposed by your controller.
You could go to a 4T or 5T wind, but you will take a slight penalty regarding the motor's maximum continuous power capability versus a 3T or 6T wind because you are sacrificing some copper fill(of the space available for 66 windings in a Leafbike motor, the 4T can only use 64 of them, and the 5T can use 65 of them, while the 3T, 6T, and 11T fill all 66). If you're only going to use a Phaserunner or Frankenrunner controller from Grin and never upgrade, then this isn't an issue, as you'll never push the motor to its limits with that controller, and a 4T or 5T will work just fine. I've used a 4T wind in a 26" drive wheel for my build with a Phaserunner controller without major issue and the motor never so much as got warm to the touch running 2,500W peak. I live in a hilly area, but my vehicle is also more slippery to the air than the average ebike, so by the time I'm doing 45 mph on flat ground, I'm well below 1 kW demand from my controller giving it time to cool. I don't even have a heatsink for the controller. Accelerating with 2,500W, I can out-accelerate almost any moped I come across and keep up with cars.
IMO, I wouldn't bother doing more than 40 mph with a Grin controller on a fat bike. The aerodynamic drag imposed on the vehicle is just too much for the controller to maintain the required power output without eventually going into thermal rollback and/or destroying the XT60 connector. If you decide to go with a 72V system, a 6T wind would give you acceleration roughly twice as fast as a 3T wind, given the 96A phase current limitation of the Phaserunner/Frankenrunner. Do note that 96A on a 6T wind will risk burning the motor out faster than 96A on a 3T wind, because continuous torque remains roughly the same between the two(the Phaserunner will fail before ever damaging a Leafbike motor). As the turn count decreases, continuous current capability of the motor itself increases(this is separate from the continuous current capability of the phase wires, which is dependent upon the size of the wire. Leafbike 1500W uses 12AWG wire).
The advantage of the 3T wind is that if you decide you later want to go to a high-end controller that can do 250+ phase amps and want to turn your fatbike into a decently quick motorcycle, the motor will be able to handle it with minimal modification. The other winds are not as suited to that task. By selecting a 3T wind, you won't need to upgrade to a 72V battery to get close to your desired top speed either. But since the Grin controllers only go to 96A phase current, your acceleration will not be as good as with a higher turn-count motor should you choose to limit yourself to a Grin controller. If you haven't ordered a Grin controller yet, and like the idea of a 3T wind motor, consider other controller options like the ASI BAC2000, Nucular, Flipsky, PowerVelocity, Sabvoton, Lyon, Lewbowski, and similar. Do your research before you buy.
