terr513
- Joined
- Jun 24, 2012
- Messages
- 30
LEE Iaccoca 36 Volt 500 Watt needs Controller? Help a girl out
I have been trying to find a controller for a LEE Iaccoca 36 Volt 500 Watt Brushed Motor
I have replaced the Throttle, Battery 8AH SLA, Derailleur, Chain Etc, The battery is putting out 37 volts but on the other side of the controller the motor is only receiving 17 Volts
This list came from the Service Manual, but there is no listing for the Motor or Battery and Accessory and Throttle are very veg in description. Would I ever get it hooked up?
I have been told I will never find one, but I'm trying to get as close as possible.
(From E Bike Owner Service Manual) not much help
CONNECTOR IDENTIFICATION
Reference Number Component/Function Connector Type
A 5 amp fuse
B Accessory control (left side) 6-pin
C Throttle control (right side) 7-pin
D Brake sensor, right 2-pin
E Brake sensor, left 2-pin
F Taillight 4-pin
G Horn (1 red and 1 black wire) 3-pin
H Headlight (1 white and 1 black wire) 3-pin
We apologize, but we do not have any controller that will even come close to those specifications. What makes your controller unique (and thus hard to replace) is how many wires the throttle requires. All of our controllers are designed for throttles with 3 or 4 wires, so they would not be compatible with yours.
Thank you,
Andrew C.
Monster Scooter Parts
800-798-0325 ext. 113
www.monsterscooterparts.com
This answer is what I have been getting.
This controller is from a different company think it might work?
http://www.electricscooterparts.com/hookup/SPD-611B9wiring.html
This diagram for controller came from http://www.electricscooterparts.com/speedcontrollers36volt.html
They also have three other controllers to choose from, bike does not have reverse.
I have owned this bike for 2Yrs still have not had a ride. :|
A 5 amp fuse
F Taillight 4-pin
Thank you,
Andrew C.
