Left-Side-Drive freewheel adapter for disc hub
Ft Riley, NE Kansas
This is from a website called "Monkey Like Shiney". He made the adapter from stainless. I didn't put this in the 'resources' stickie, because they are not for sale, but this is what they would look like if someone wanted one, and needed a pic to describe it to a machinist. You bolt the adapter onto the disc flange, then thread the freewheel onto the adapter.
I suppose if you used a large-diameter brake-disc sandwiched between the adapter and the hub, you might be able to have both (drop-out spacing providing enough width, of course). I believe if you file two keyways between the two parts, a common freewheel with right-handed threads wouldn't unscrew itself...
http://monkeylikeshiny.blogspot.com/
johnrobholmes said:
Yeah, you would certainly have to have reduction already taken care of to use such a small rear sprocket.
Or have it as your manual pedal drive line like i did on my own bike...
KiM
