I finally got my first test ride with these in late yesterday afternoon. Bottomline is that I couldn't really tell the difference between this 24s 80V/10Ah LiFeBatt setup, and the 24s6p 80V/13.8Ah a123 setup that is usually on this bike. It feels exactly the same, which is good news.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I really gave this about as hard a test as I could, which is multiple dead stops going up hills. I pretty much just maxed out the throttle as much as possible.
Here's what the setup looks like:
I didn't do anything to tidy up the wires, etc., as this bike normally has the a123 setup. These packs are going on my wife's new Townie, which I hope to finish up today.
As I said, I did my best to "work" the packs. I hit multiple 76-77A/4500W peaks and had lots where I just kept the load on for as long as possible. Some were long enough that the current dropped to about 50A and the voltage dipped to about 32.5V per pack, which is about 2.7V per cell. I've done similar tests with the a123 setup on this bike, and the voltage dipped to about 2.8V per cell for the same sort of long full throttle climbs up a hill. This is exactly what I'd expect, given that the a123 cells have a bit higher "C" rating, and that the 6p a123 setup is 13.8Ah vs 10Ah for the LiFeBatt cells.
Here's some shots of the two WattsUp readings:
As you can see, I went a total of 5.5 miles and the "burn" rate is close to 1Ah/mile, which shows how hard I pushed these. My normal usage rate is about 600 mAh/mile, on a normal ride through the hilly terrain around here. I was going to try and do a video yesterday, but i was losing light, and didn't have time to rig the camera/unipod. For the next ride, I'll do this for sure.
All-in-all, I'm quite pleased. I was hoping that they would have similar performance to my proven a123 setups, and I was not disappointed. I'd put these up agianst any of the Chinese LiFePO4 imports any day, even those with higher capacities. That's the rub with most of these, you have to use cells that have large capacities, like 20Ah, in order to keep the voltage drop under load from killing the cells in higher powered setups like i'm using, which can see 4500-5500W/75-85A peaks.
More later...
-- Gary
