Lifepo4 26650 capacity tester
Masterbee
Hello.
I would like to run capacity tests on ~500 A123 26650 cells before I blindly turn them into a pack.
I first purchased and ISDT Q6 charger to charge 4S packs and capacity test them, but it only checks capacity of the whole 12 V battery.
Next up I purchased a XTAR VC8 on hopes of that testing individual cells. No dice. It seems to only capacity test from 4.2v down.
Does anybody know of A charger to fit the bill? I can’t imagine I’m the only person wanting to test these very popular reclaimed cells.
Thanks
There may be info in one or more of these threads, though not all of them are relevant you can tell by title which ones might be:
https://endless-sphere.com/forums/search.php?keywords=Lifepo4+test*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
https://endless-sphere.com/forums/search.php?keywords=a123+test*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
There are also other threads specificaly about the cells in question that are not listed there due to different titles, etc.
i tested 200 of the a123 26650 with 2 of my opus. i had to buy 26650 individual holders 8 of them and then wire them to the opus. You have to open up the opus to flip a switch to the lifepo4 setting.
Its alot of extra work to get everything setup, but the opus worked great. it didn't take long to process all 200 cells (tested at 1 amp), the a123 cells charge and discharge faster then the 18650 cells do. If I had to test more a123, I would do it the same way with the opus.
If you already have some opus, its the way to go.
On my 200 cells i got anywhere from1400 to 2300 mah.
The opus looks great. Soldering in a few battery holders is minimal work compared to making a big battery.
Thanks
