elastictrickery
10 µW
Hi everybody,
One of my LiFePO4 batteries has gone down.
In my LWB recumbent I have two Valence Saphion batteries of 60 cells each configured 5s 12p - 16V 14Ah. I used to run one after the other, until I discovered I could get quite a few more miles by using them together (16V 28Ah) they are separate until I switch the two 70amp relays. This has worked well until yesterday. As it’s been really cold and wet I haven’t used the machine for several weeks, so I decided to ‘exercise’ it. Both batteries were reading 16.56V and 16.54V when I started them off spinning the back wheel at 30 mph in fourteenth. I put a clamp on the Magura twist grip to hold it open, and checked it every 15 minutes. The Hacker controller was set to cut at 11.5V
After about two and a half hours I was surprised to find the revs had dropped and the data-logger showing 9.8V!!!. I closed the throttle immediately and the (combined) voltage crept up to 12.1 V. I have no idea why the ESC hadn’t cut. And I was somewhat annoyed that the logger was showing that only 21Ah had been used – when I’ve done this in the past It has shown nearly 30Ah but that was in the summer - It’s very cold in my workshop now – could this be part of the problem?
In retrospect it is unfortunate that I didn’t check the voltage of each battery individually before I started recharging. Number 1 battery came up to full capacity in 1hour 56 minutes. I put Number 2 battery on charge – but after 36 minutes the charger cut out at only13.3V. Some thing doesn’t add up here. Having taken both batteries out of the case I checked each 12 cell parallel string - four of them are reading between 3.34 and 3.32 - one is dead. There is no swelling or discoloration on any cell
I suspect that Number 1 battery was only down to 14 volts or so when I switched off, as it would normally take about three hours to recharge if it was down to 11.5V. I haven’t got the batteries wired for a balancer –I was told by the supplier it wasn’t necessary with this chemistry. And five years ago when I made this machine I couldn’t find a balance charger for LiFePO4 batteries as big as these. I had just decided to fit balance leads - in fact I was looking at leads, plugs and adaptors in a catalogue while all this was going on! Ironic or what!
What do I do now? Will the whole string of 12-cells be irrevocably dead or just one cell? If it’s just one cell - can I fit a new cell? I suppose I’ll have to tear the whole battery apart to do anything. I would be very grateful for suggestions.
Thanks.
Thanks.
