powermed
- Joined
- Jun 22, 2008
- Messages
- 80
Can someone either refute or confirm my research? I haven't seen anything to suggest there's a definitive relationship between C ratings and the quality of a battery. For my application (an electric boat) I'm needing few cells with a high AH capacity and [relatively] low C ratings. The cells I'm looking at are 200 AH / cell, with a discharge rate over 200 AH (see below). I'll be charging each of the 8 cells individually at over 60 amps). I never draw more than 35 - 50 AH, so that discharge limit will never get challenged.
What I've read is that while cells like A123's have very high C ratings, it's due to technologies applied to the cathode. The cells I'm looking at are large format LiFePO4 cells with very good test / life cycle data (same as the best I've seen - 1000's of cycles, drop to 80%) with low impedance and low C ratings. I've never seen any data on shelf life - so unless someone has it - I'm guessing such talk is just a bunch of guys sitting around talking philosophy.
In sum, I can't see any justification for spending 2 or 3 x the price to obtain higher C ratings.
z.
3.2V/200AH
Can Material
Plastic Can
Typical Capacity
200Ah
Minimal Capacity
199.5Ah
Nominal Voltage
3.2V
Max. Charge Voltage
3.65V
Discharge Cut-off Voltage
2.0V
Max. Charge Current
1 C(5)A
Max. Discharge Current
2 C(5)A
Battery Size
82*182*278mm
Weight (Approx.)
≤6.40Kg
Impedance(Max, at 1000Hz.)
≤1mΩ (charged status)
z.
3.2V/200AH
Can Material
Plastic Can
Typical Capacity
200Ah
Minimal Capacity
199.5Ah
Nominal Voltage
3.2V
Max. Charge Voltage
3.65V
2.0V
Max. Charge Current
1 C(5)A
2 C(5)A
Battery Size
82*182*278mm
Weight (Approx.)
≤6.40Kg
